跳转到主内容
The BlackBerry Passport SQW100-1 is a phone that has a physical keyboard and a touchscreen feature in one. Its square-like shape sets the BlackBerry Passport SQW100-1 apart from the other BlackBerry phones.
How do I get past the Finalizing Device Setup screen?
I turned my passport off the other day to avoid it ringing during a movie. Since I turned it back on two days ago, it has been in a loop where I get the 'Finalizing device setup' screen. It get to 100% and then restarts the whole thing over again. Have tried soft start from the power button, soft start from the volume toggle keys and most recently have removed and reinstalled the battery. Each re-set starts the pattern all over again. Help :-)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Try removing the SD memory card. Then restart the device.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same issue...uhg!
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem twice with my Passport. The only solution I’ve found is to re-install BB10 OS and it worked. Via BB Link, I downloaded BB 10 on my PC and could install it. Caution : BB Link cannot be installed on Windows 10, and you must know that you will loose all your data if you do so.
(excuse my bad english, I’m french)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Julie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 19
总计 6,860
