跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Replacing Home button & Finger Print functionality
I have replaced my iPhone 5s home button
the home button worked fine but the fingerprint not working
and every time i restart my iPhone it showing a message stating "Unable to activate Touch ID on this iPhone".
Someone said:
The home button that comes with the iPhone is the only home button that will work with the fingerprint scanner, any other after market home button that you put in your iPhone won't work as fingerprint scanner, but just as home button.
is that correct ???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Even if you get a original home button from another iPhone touch ID won't work anyway.
完成的
error "unable to activated Touch ID on this iPhone" when they are replaced. My iPhone 5s didn't show that error, but when I hit "add a fingerprint..." menu, it show next page, but next nothing happen when I put my finger on Touch ID, any idea whit this? Error show only when I try to turn on the phone with flex cable disconnect from logic board, last try hard reset, restore, install IOS 10.3 then back to iOS 10.2.1, disconnect battery connector, nothing fix
完成的
添加一条评论
2个答案
已选择的解决方案
Unfortunately, it is correct. Replacing the home button will lose Touch ID functionality. In the iFixit repair guide, it states this in the Introduction at the top the guide: iPhone 5s Home键更换
Sorry.
这个答案有帮助吗?
得分 1
1条评论:
how to identify that home button has been replaced? is there any difference that error report on IOS software occurred between fingerprint hardware failure or cause by non original part?
完成的
添加一条评论
最有帮助的答案
That has been true since the first day iPhone 5s is introduced and has been asked again over and over, it is starting to get silly asking again.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Samih Ghonaim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 977
