跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5s Turns Off by itself
So I have had this iPhone 5s since it first launched, and the batt died last August. Got a battery replacement mid December.
Problems:
1. The phone would mysteriously die when not in use. In 24 hours it'll for sure turn off by itself. Over night it'll shutoff. Keeping iPhone plugged in doesn't solve the problem, it'll still shutdown.
2. When around 20% batt left phone would shutoff, when plugged in will turn on again normally.
3. Changing to another batt didn't solve the problem. I bought like 5 replacement batteries, none of them fixed the problem, tried them on my other 5s as I have about 4 of them, worked perfectly fine, no random shutdowns.
Question:
Which ic chip is most probably busted? Main power IC or the U2 chip? Or is it something else??
PS.
In diagnostic there is Panic code
Update (03/07/2017)
@benjamen50
which one? the one @ the very right?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Wait a second what is the kernel panic code?
完成的
添加一条评论
4个答案
已选择的解决方案
Power management IC no doubt. U2 Tristar Charging IC does not cause this.
这个答案有帮助吗?
得分 2
4条评论:
I have an iphone 5 with the same prob, so U2 of both phones busted?
完成的
It's not U2 it's PM IC.
完成的
If the main power ic is busted it won't even turn on right?
完成的
No because I have a iPhone 6 with this exact same issue which causes intermittent shut down issues (Already tried another battery).
完成的
添加一条评论
Before you go into the motherboard troubleshooting I would suggest that you charge the battery up to 100%, open up the phone, disconnect the charging port and proximity sensor and see if it still shuts off. If the problem is gone then re-connect the parts one by one until the problem re-occurs.
这个答案有帮助吗?
得分 1
3条评论:
Proximity already changed as it was broken, didn't solve the problem. I will try to unplug the charging port as well, thank you, will get back to you in about 9 hours.
Previously I'd thought that unplugging the proximity oughta fix it, it didn't, so I changed it, didn't fix it as well.
完成的
So far its still on, I'll see for a few days if it'll stay on like this, usually when batt gets around 70% it'll start turning off fast.
完成的
To be sure that it doesn't happen during this activity, open up a 10 hour long YouTube video and let it run for a while
完成的
添加一条评论
My iPhone switches off when I lock it or when it’s go to sleep mode and for me to use it the screen must be on all the time please help
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
i would send it to the store you got it from and see if they can do anything about
这个答案有帮助吗?
得分 -1
1条评论:
Haha I got it back in 2013, in Tokyo, I'm currently in Jakarta
sad(T ^ T)
完成的
添加一条评论
添加你的答案
Anon545454 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 7,052
