跳转到主内容
于2015年十月26日上市的第四代Surface Pro平板电脑。
Blurry texts and screen flickers
Texts are blurry, screen flickers and video/image moves under frozen one.
How to correct it ?
Image and text on the screen use to tremble, up and down, from time to time. When this happens image and text become blurry.
When video is playing,sometimes, one frame freezes, while in the background the video is still playing.
Is it a software related problem or a hardware malfunction ?
(once I hooked the Surface to a monitor, the video played fine,while the problem persisted on the Surface screen)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
11条评论
Hi,
If it was software it should also affect the external monitor.
It could be a video cable or a tablet screen problem.
How long have you had the tablet?
完成的
I have the same problem with my Surface pro 4, which I have had only for about 18 months, the problem started several months ago, and is getting worse. It makes it very hard to do projects! I have searched the Internet to see if there is a way to fix this problem. I love the Surface Pro 4, but unless Microsoft comes up with a solution, I would not buy another of their products like this! Microsoft needs to fix this, as many are experiencing the same issue!1
完成的
My surface screen is going blurry, looking like multiple docs are open on top of each other. Can’t read any of it. Screen becomes unresponsive. Does anyone have any advice? Thanks
完成的
I am experiencing the same thing on my surface pro!
完成的
I just started having this problem. My surface pro 4 is about 17 months old. Happens when the device gets hot.
完成的
显示更多的6条评论
添加一条评论
2个答案
已选择的解决方案
Call Microsoft, this is a known issue covered by extended warranty.
这个答案有帮助吗?
得分 2
添加一条评论
This worked for me. https://www.groovypost.com/howto/fix-fuz...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emilcar Similien 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 17,291
