跳转到主内容
Repair guides and support for Fujifilm's FinePix line of cameras.
160 个问题 查看全部
My lens is stuck or jammed in the closed position. Is there a fix?
I have an AX660 that has lens that will not open. It is as if it is jammed or stuck. It may have been dropped. I have tried clearing any small debris around the lens by using a small flat-head screwdriver and by blowing compressed air into it, and all that was done to no avail. Any suggestions on how to fix my lens (even if it means disassembling the camera) would be greatly appreciated. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try this guide to dissamble the camera:
Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement
But be careful and have rubber gloves on (it amy be shocking). I’m trying to fix same problem with my J30 old camera but all the black tape and grounding making it quite difficult to remove the lens safely.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Gilbert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 21
总计 233
