跳转到主内容
Improved second generation Google-branded tablet with a 7" screen.
Touch screen not fully working
I dropped my Nexus 2nd G and cracked the glass. The top portion of the screen now did not respond to touch. I have replaced the LCD and digitizer and it still does not respond...only the bottom of the screen. Do I need to replace the LCD Ribbon Cable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
More likely chances are there that you might have damaged the connector cable. Check on it. Or even it can be loose connection also.
Get it installed frm professional.
这个答案有帮助吗?
得分 1
1条评论:
How do you check the cable to see if it is broken? The connections don't seem to be loose since they lock in place.
完成的
添加一条评论
添加你的答案
Carla Edgar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 223
