跳转到主内容
Use this repair guide to fix faulty parts in the Fujifilm FinePix S2980.
12 个问题 查看全部
SD card will not insert
My SD card won't click into place in my camera like it use to, it won't lock in so I can't use the camera without the SD card
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It may be problem with metal clips holding the SD card. Try to adjust them. I think camera has internal memory to place a few pictures without SD card.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your advice. I’ll try adjusting the clips.
I’m not sure if the camera has a memory, but I’ll look in the owner’s manual.
Thanks again.
Mike
完成的
添加一条评论
添加你的答案
Emma 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 171
