跳转到主内容
加入维修社区 - 创建账户
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
Stuck on installation 2nd DVD
Hi,
Having purchased a 2nd hand Mac Mini, and upon a fresh installation of the provided original software, I got stuck on the 2nd DVD...
It simply doesn't do anything, and the message on the screen is 'Preparing for Installation'.
When I reboot the Computer, it asks for the 2nd DVD. When I insert it, it spins a couple of times and it completely stops!
Any help? Fear I have a nice decorative brick, now! :(
Regards
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Reformat
the HD. Start a complete new install. You can't just restart in the middle of an install sequence. Ensure your 2nd DVD is not damaged! If it is and you have access to other Macs or HDs you might be able to do a clone or restore in Target Mode on the Mini.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 1
1条评论:
Start with the install disk in the machine (you can option start to choose that startup disk). Once you choose language go to TOOLS on the menu (do not start or restart the install if asked), Disk Utility->Disk First Aid:Partition will allow you to erase/reformat the disk and start a new install.
If you mean copy that 2nd disk to a HD (if it will copy). And if you connected that HD when asked to insert disk 2 it might work (provided there's nothing else on the HD).
完成的
添加一条评论
Thank you for your help.
However, when I boot up my mac mini that installation screen asking for the 2nd DVD comes up, and I get stuck there. How can I bypass that?
I think the 2nd DVD might actually be damaged. Can I performan install from a hard drive, for instance?
Thank you
这个答案有帮助吗?
得分 0
1条评论:
Please post this as an Update to your Question, or a comment to my Answer. Only Answers belong here.
完成的
添加一条评论
添加你的答案
antonioamalves 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 23
总计 1,114
