跳转到主内容
问题已关闭
Need Part only - Dgitizer Glass Toshiba Satellite Radius P55W-B5220
Hello, everyone!
I need the Glass digitizer for a Toshiba Satellite Radius P55W-B5220
I see a few Whole LCD digitizer assemblies but all I need to replace is the Glass Digitizer that cracked in one corner, The LCD works and all is fine, just the three inch crack on digitizer and it does not respond!
LCD is fine and I can use the Keyboard/mouse etc!
Anyone know who has one or where I can locate one?
I have searched eBay and all over!
I appreciate the assistance on this!
CG
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
http://www.ebay.co.uk/itm/like/182206661...
^Closest available, would recommend emailing seller to make sure it is compatible. Also check for repair videos on your model, to make sure the LCD and glass are not glued together, which will make it a lot more difficult to do the repair.
这个答案有帮助吗?
得分 1
1条评论:
Hello Reece,
Not but thank you I have a ton of those links that you suggested and they are all for the C Series!
I need the P55W-B5220 Or at least to get close the P55W-"B Series"
Most on the P55W digitizers Glass replacements available as the one you suggested are all "C" series!
I have asked all those with the LCD Assembly as well as the ones selling the C Series about the B5220 or B series and they say they don't have it!!
I am calling HP on Monday to find out if in fact the Digitizer cannot be purchased alone and if it has to be purchased with the LCD together as in assembly! The whole assembly is averaging in prices of $ 225
Thank you
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 299
