跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
boot loop after battery replacement
my iPhone 6 had battery problems like most iPhones these days battery percentage was all over the place jumping up and down for example from 40 to 5 % after suffering that for many months now I decided to have the battery replaced so I changed the battery at a repair shop yesterday not at apple cuz I don't have official apple stores where I'm at , now since morning my phone started suddenly restarting and stuck in boot loops for minutes then powering on , but as soon as I start using it , it goes in boot loop again and so on , when connected to a power source it's working fine , once disconnected the same happens, any idea of what the problem is ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
3个答案
已选择的解决方案
It's a bad battery. Take it back to where you got the battery replaced from.
These are common symptoms of a refurbished / repackaged / aftermarket non-original battery DOA (dead on arrival).
这个答案有帮助吗?
得分 6
添加一条评论
Ew. That shop needs to replace that battery out and do a proper volt test on it. Like Ben said before, it's a bad battery and might be part of a bad crop or by itself.
这个答案有帮助吗?
得分 2
添加一条评论
I don’t know if this will get added to this discussion, but I had a similar problem. I replaced a bad iphone 6s battery with one purchased through Amazon. It is a little tricky getting the old battery out and this is where my problem was. I unfortunately lost a couple tiny screws in the replacement process. The critical screw is the one holding the metal cover tight over the connection between the battery and iphone. I reinstalled without that and the connection was not tight (enough). The phone would start and be fine….for a couple minutes and then reboot. I opened the cover and scavenged another screw (needs to be the slightly longer one) and tightened that cover down well. No more problem with restarting.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
hero_2123 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 8,931
