跳转到主内容
Repair guides and support for tablets produced by Lenovo including the ThinkPad tablet line.
lenovo MIIX 700 and it doesnt boot
I have a lenovo MIIX 700 and it doesnt boot I tried it all and I cant find a reset hole to stick a clip in . I need help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hello. I have quite same problem, after updating the bios, it crashed, so first I could go to the bios so I did to check settings, and now it continually reboot on the Lenovo logo... Can you help me please? Or is my motherboard dead?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Does the tablet indicate that it is charging when you connect the charger to it?
When you say that you tried it all, did you try to reset the tablet using the Volume Up and the Power button to get into the recovery menu? If so what happened?
Here is the procedure:
Shut down the computer and wait at least five seconds.
Press and hold the Volume Up button and then press and hold the Power button, (both buttons are now held together) until the Novo Menu appears on the screen.
Novo menu > System Recovery > Troubleshoot > Reset this PC
Here is an image taken from the user guide that shows the options available in the Recovery menu. Be aware of which option you choose in the Reset menu as you could lose all your data if you choose Remove Everything and restore the tablet to its' factory default condition. Select Keep my files as highlighted in the image.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 3
1条评论:
Tried this but no Novo has come up. No sure what else to try
完成的
添加一条评论
添加你的答案
stephaniexxme 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 8,555
