跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Replaced front panel, ear speaker doesn't work now?
I recently replaced my front panel and all went well... everything worked great for about 2 weeks, but now my ear speaker doesn't work at all. All phone call have to be made using speaker phone or ear buds because I can't hear anything. I tried taking it all apart again and putting it back together to make sure I didn't have a loose connection, but it didn't help. Can anyone help me? Any ideas? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
After taking it apart 3 more times and reconnecting everything...it's working again! Hopefully everything continues to work! Thanks everyone for your responses!!
完成的
添加一条评论
3个答案
Either a connection broke loose or it just plain broke. You might just need to replace it. Im not going to put a link of how to do it as you already seem to know how.
Hope this helps and good luck fixing!
这个答案有帮助吗?
得分 0
添加一条评论
hi
its pls check speaker connection is good or not by using multimeter... put optiom in beep mode and check the two point in two probes if its beep comes your speaker is working.... if its not working replace the new one and check 100% its works
ear speaker
这个答案有帮助吗?
得分 0
添加一条评论
If it worked fine for two weeks and you haven't dropped it or got it wet, most likely the ear speaker, shown in the picture above, is not aligned with the front camera and sensor flex cable. You should be able to get it working by re-aligning the ear speaker with the gold contact points on the flex, and make sure you put the correct screws holding down the ear speaker bracket to secure the ear speaker down properly so it doesn't move.
Alternatively if it does not work, it may be possible that either the ear speaker itself, or the front camera and sensor flex wen't bad. However, these parts don't go bad "just because"
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Morgan Riley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 56
