跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
Why does the Restart Instruction keep popping up?
Recently my phone has had the Restart Instruction , "To restart your phone, press and hold power and volume up buttons for 10 seconds" popping up all the time without me even trying to restart my phone. I try to take it off by hitting the screen on/off button and it goes away after a few click, but it ends up coming back. I'm still able to use my phone but the message is right in the middle of the screen so it makes it hard to see what i'm typing. When I hit the home button while the message is still on, it'll take a screenshot. Also sometimes when the message goes away and it looks all clear, I hit the home button and it still takes a screenshot. Like if the message was still there just invisable. It's been happening for a while and it's gotten very annoying and frustrating
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Simply because your ON/OFF Button (top-right) is stuck in ON!
The fix:push it repeatedly while nudging in back and forth with finger nail.
Worked for me. Could be that standard skin grime made it stuck. If this problem returns I think I will exchange this beast of a button.
这个答案有帮助吗?
得分 3
3条评论:
Thanks man, worked on my HTC 10 the button popped right out appreciate the tip, cheers.
完成的
it worked thank you.
完成的
Thankyou this also worked for me. HTC m8
完成的
添加一条评论
Best option is to back up your data and wipe your phone. This will hopefully rid of what ever is doing that
这个答案有帮助吗?
得分 0
2条评论:
How do you wipe the phone ? Are you saying to do a factory reset ?
完成的
This did not work for me. The above suggestion worked perfectly though
完成的
添加一条评论
I had this exact problem after doing a micro USB replacement yet it somehow went away (button might’ve been stuck since I slightly damaged the plastic piece during reinstallation given it’s loose in the metal case)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Felix Morales 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 4,945
