跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why is my iPhone not turning on
when i try to turn it on without the charging cable in it, it doesn't turn on it is just black but when i try to charge it it shows the apple logo for a second then shut right back off and keeps doing this.
I have dropped it a couple of times
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
When you plug it into the charger, press and hold the home button when you plug it in. It should show a iTunes logo and a cable. Make sure it is plugged into a computer. Restore it in iTunes and see if it works then. If that doesn't work try this guide: http://www.jailbreakmodo.com/iphone-5s-d...
这个答案有帮助吗?
得分 1
6条评论:
does not work when i press ad hold down
完成的
Try the link I posted.
完成的
isnt working
完成的
What does it do? Go back to the bootloop? If you did it correctly, the screen should be black. iTunes would also detect it as a phone in recovery mode.
完成的
It is just still black
完成的
显示更多的1条评论
添加一条评论
Are you a game lover, If yes, then I am sure you have to introduce with lots of game because the Internet is full of awesome games nowadays and daily you have to introduce with lots of new games. There are many games available which are surely on your favorite list and you play them every day.
http://www.latestapkapp.com/2017/09/tutu...
这个答案有帮助吗?
得分 0
添加一条评论
Connect your device to your pc and then launch 3uTools, and then try to enter DFU mode. If 3uTools detects that your iPhone is on DFU mode, you can easy flash your device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Prince Bowdre 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 121
