跳转到主内容
加入维修社区 - 创建账户
第三代配备 Wi-Fi 的 iPad,于 2012 年 3 月 16 日发布。型号A1416。维修需要加热并小心撬开它。
Charging problem after battery replacement
Replaced the battery on my iPad 3 today due to the old battery not charging. The problem I am having is after I replaced the battery the iPad now continuously connects and disconnects while plugged in. I have triple checked all of the connections and everything is plugged in properly and all connections are clean. Any idea as to why this is happening?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
When you say you have triple checked the connections, have you checked to make sure the contacts on the battery are making a good connection to the motherboard? Did you test the charging and functionality before closing the iPad back up?
这个答案有帮助吗?
得分 1
1条评论:
I initially thought that might have been the issue so I put a small shim under the battery contacts. That did not solve the issue. I closed the iPad back up, but it's easy to tear down again if I need to because the adhesive needs replaced.
完成的
添加一条评论
Sounds like it might not have been the battery that was the culprit in the first place. Do you have a new charging port to try? Worst case scenario it might be an IC issue, more specifically the U2 IC might be fried.
这个答案有帮助吗?
得分 1
1条评论:
I don't have a new charging port, but I can easily get one. I'll replace it and update.
完成的
添加一条评论
添加你的答案
jeninholland02 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 29
总计 290
