跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
earpiece not working but in different phone is working
Hi everyone
I have problem with one iPhone 5C, the earpiece won't work but if you press on it works.
I replace the screen with new earpiece and new proximity flex that are working in different device and still it doesn't work when I place back in the phone.
Anyone had this issue before?
Thank you for your help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Could it be the screen frame? I've seen screen frames where they have caused horrible installation of the metal plate and two screws for the earpiece / front camera assembly.
这个答案有帮助吗?
得分 3
1条评论:
Hi Ben,
I have tried with numerous screens and is still not working.
I have put full assembly screen with all installed that work in different phone and when I put it in the one with the issue doesn't want to work.
So I guess it is not the screen it is motherboard issue but I don't know where to look and what to do.
If you have any ideas I will appreciate the help.
完成的
添加一条评论
Probably you have damaged the J1 connector or a part near this connector. See the schematic, check pins 24,26,28 and parts that connect to this pins.
这个答案有帮助吗?
得分 0
1条评论:
Thank you very much for your answer.
The phone came with this problem and I just couldn't fix it :)
I will check this pins and see if any of them are damaged.
完成的
添加一条评论
添加你的答案
Mimi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 9
总计 66
