跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
My iPhone won't respond at all but iTunes recognised it as a recovery
A bit of backstory this phone was a gift from my brother because I like to tinker he gave me a iPhone 5c and a iPhone 4 the 5c is real weird so the screen is cracked on it and I try to power it on it won't respond I thought it was dead flat so I put it on charge after 3 days on charge and no response no viabrating no speaker sounds nothing so I plug it into my computer iTunes recognised it as a iPhone in recovery mode but at the moment with my internet the way it's is (0.06 kb a second) I can't recover it what should I do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
It likely that your phone is charged but there are no sound or vibration because the phone won't boot. If the screen was working you'd probably see the "connect to iTunes" screen. I'd restore the phone through iTunes and see if you then get setup screens in iTunes confirming that the phone has restored and booted successfully then replace the screen. However if I doesn't restore look at th lightning port or battery as a first port of call.
完成的
添加一条评论
1个答案
many problems could be causing this, however these are the more common ones.
1) DFU Mode. DFU mode is a recovery mode apple uses to bypass certain limitations of standard recovery mode. in DFU mode, there is no image displayed on the screen. To get it out of DFU mode. simply soft reset. Press and hold Home, and power for up to 15 seconds, or until the apple logo appears.
2) Screen Failure. the device could simply be on silent, with a failure in your LCD. This failure could be caused by either the LCD itself being bad, or the Image processing chips failing. The first of which is a simple repair, and there are plenty of guides on this site for it. The next is much more intricate, and requires a specific skillset. leave that type of repair to paid technicians.
3) Water damage. I see screens fail, and forced recovery mode frequently after water damage. bather the board in isopropyl for 5 minutes, then give it a stern scrubbing with a toothbrush. then bather it in the isopropyl again. This MAY fix the issue.
4) further board failure. The mother board could have extensive failures beyond repair. at this point, it makes more sense money wise, to just replace the device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bailey smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 72
