跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 个问题 查看全部
wifi signal very bad after screen replacement
Hi All.
I recently cracked the screen on my ipad 2. Despite the crack the wifi and screen worked perfectly.
Not wishing to damage it any further I carefully transported it to a tech repair company, who replaced the screen.
Once I got it home I found the wifi range had reduced from 30 feet to 1 foot.
Have spent lots of time with my internet provider trying other options to improve it, with no success.
My question is "could the tech company have damaged the wifi aerial when they replaced the glass?"
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi. Yes they most def could damaged the Wifi Antenna as it adhered just the the R/H of the home button. Poor Wifi is very common on iPad 2 after Digi replacements if you don't know what your doing. You can ask them about replacing it but I don't like your chances as you maybe up for another screen. Hope it works out
这个答案有帮助吗?
得分 1
1条评论:
Hi Lee. Thanks for your prompt reply. After they replaced the screen there is now a fine vertical opaque line which they accept shouldn't be there and they are going to do it again. So hopefully they can sort the antenna at the same time. Do you think this will be possible?
完成的
添加一条评论
添加你的答案
MatthewRalphs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,321
