跳转到主内容
加入维修社区 - 创建账户
iMac 21.5"(Intel)維修指南及客户支持
very slow while starting
it is taking to much time to start my iMac.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
How about telling us your exact model you have as there are issues on some versions of the 21.5" systems that can effect things here.
完成的
添加一条评论
2个答案
已选择的解决方案
It sounds like you need to do some TLC on your drive:
  • Start off by making a good backup of your stuff.
  • Using an external bootable drive run Disk Utility from it to make sure the drive is in good shape.
  • You'll need to clean off at least of 1/4 of the drive (the more the better) of old documents and apps.
  • Next we want to get rid of the old cache & log files using an app like this: Disk Doctor
  • Last step! Run a drive defrag program like this if you have a HD (not SSD): Drive Genius
Other things that can help is add more RAM if you can with your system. If you have a traditional HD consider upgrading it to a hybrid (SSHD) like this one: Seagate FireCuda but be careful here as these drives only work in SATA III (6.0 Gb/s) systems if you have an older SATA II (3.0 Gb/s) you'll need the older series. The other option is to upgrade to a SSD drive like this one: Samsung 750 EVO SSD which will work in either a SATA II or SATA III system but the larger drives do get a bit costly so make sure its a wise investment given the age of your system.
这个答案有帮助吗?
得分 2
添加一条评论
Shamaun xrry about that,it has problems with the operating system, gentle cleaning is needed or delete inactive services to create room for the machine to run faster.
Tonny entebbe uganda
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
shamaun1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 126
