跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Forced Recovery mode, Error 4013 on recovery
Hey guys. I have an iPhone 5C here with a recovery mode forced into the device. i boot up the apple logo for 2 seconds, then switches to recovery mode. I connect it to itunes, and try to restore and update.
The update downloads all the way fine, then extracts well also. the problem arises while the device is "preparing iphone for install" (Waiting for iphone). When this happens, it switches to the apple logo, like its about to install, but instead of the standard progress bar, it turns off, then on again, and goes right back to recovery mode.
i verified continuity on the power button and home button
i tried 2 OEM USBs, tested on other apple devices fine
i replaced the charge port, from a separate device, that was working fine
i tried 3 different PC ports, including a 3.0 port
i tried both my laptop and desktop computer.
none of these fix the issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Have you tried running a bare-bones system...battery, Lightning port, logic board and screen to see if this helps. Some techs report issues with proximity or camera.
This could be NAND related. I had a 6 that did essentially the same thing. I tried all of the above and then some, even reballing the NAND to no effect. Based on the research I did, it is a corrupted NAND.
Perhaps others will have different or better ideas.
这个答案有帮助吗?
得分 2
4条评论:
thank you for the advice, i just ran the Barebones Circuit through the update , and unfortunately it did not fix the issue.
完成的
I feel your pain. I ordered a NAND programmer...hopefully it will solve my problem.
完成的
Did you get an ip-box 2? Want to get one of those but didn't know if it's worth it.
完成的
I was looking at the Naviplus Pro3000
完成的
添加一条评论
添加你的答案
Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 255
