跳转到主内容
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 个问题 查看全部
Solution to unresponsive volume buttons?
ZTE ZMax Z970. The volume buttons are randomly responsive, will work for an hour or two before I have to go back to adjusting my volume through settings. I'm not sure if this is a hardware issue or software. Possibly related: adjusting the headphones jack when something is plugged into the phone causes the Google app to open up and listen for commands; sometimes, it will suddenly increase the volume in increments and I have to manually change it back. Where would I take it to be repaired?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
You should download the app called
Virtual volume button that should fix the problem
这个答案有帮助吗?
得分 2
添加一条评论
Okay so I'm not exactly an expert but press the center of the volume buttons into the phone and that fixed mine actually a little bit to where they are more responsive. If that doesn't work then play with the buttons to find an angle they work at.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Cassandra Pentaghast 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 7,407
