跳转到主内容
How do I remove an ASA dial from Fuji Film Fujica ST605N camera?
How do I remove a ASA dial from a Fuji Film Fujica ST605N camera?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The ASA dial is screwed down by a single screw in the middle of the dial. Using plastic rod or wood dowel that is just the same diameter of the head of the screw which then has a piece of rubber attached to its end you can fashion a friction screwdriver to unscrew the slot-less screw.
Here is the service manual for the camera: Fujica ST605 service manual it's exactly the same as your ST605N.
这个答案有帮助吗?
得分 3
1条评论:
Thank you I will let you know if this works. Thanks for pointing me in the right direction
完成的
添加一条评论
添加你的答案
keith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 914
