跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Front facing camera mis-aligned with its window
I have struggles aligning my front-facing camera to go co-axial (centered) with its window on the front panel, although the plastic bracket underneath is correctly in its place and the camera is positioned well into the plastic bracket's two grooves. It has no functional effect, the camera's field of view is alright, but it looks silly from the front. Any ideas or experiences regarding this issue would be appreciated. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Are you using the plastic gasket that holds the front camera?
完成的
Yes, I do.. I have just seen a video though where the guy used glue to fix the camera bracet. The problem might be that I haven't used any glue and the bracket slides off from position... Could you confirm? Thanks
完成的
添加一条评论
1个答案
If you transferred the clear plastic gasket and it's still misaligned, then the camera "hole" on the new assembly may be slightly off center. This can happen with less than "high quality" replacement parts or parts that are not spec'd to OEM standards. Do you have another screen replacement you can try?
这个答案有帮助吗?
得分 0
1条评论:
Unfortunately I have two new identical screens from the same seller, I cannot compare.
完成的
添加一条评论
添加你的答案
Tamas Korodi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 261
