跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
S6 Edge is shattered on the back- heats while charging-won't turn on.
The S6 Edge is shattered on the back. It is shattered to the point where your hand gets scratched when you pick it up. Right after the moment when the phone shattered, the phone was completely responsive. However, after a few hours, the phone would not turn on. I have tried charging it, and it still does not turn on. All that the phone does is warm up. Is there any chance that the phone is repairable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@maxdes , Maxim D , Yes there is a chance the device is repairable, for now stop trying to power it up/charging as you may be damaging it worse(causing a short). I will post a link at the bottom to a tear down guide of your phone, You can dismantle your phone from the guide and see if there are evident damaged parts and replace them, You will also want to look over the board carefully for any loose components, cracked solder joints,etc.. There is no guarantee that you will fix it, but does not hurt to open it up and check it out. The second link are some parts that are available from the iFixit store, select your model to see what is available at the link. If you feel you prefer not to fix device yourself have a good local computer/cell phone repair shop take a look and estimate repair. Good luck.
三星盖乐世S6 Edge拆解
[[ 无效部分链接 ]]
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Maxim D 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 266
