跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
The display loses sensitivity, sometimes goes blank.
iPhone 5s.
The display (and apparently to phone) does not work unless the upper left corner is depressed (pinched between thumb and finger), when depressed it moves noticeably, about 1/32 to 1/16 of an inch. If it is held depressed, display and touch sensitivity seem to work fine.
Opened the phone, found a screw that was not in its place, and one that was loose (I tightened it). The loose one was in the area of the upper left in the screen assembly.
I could not find where the displaced screw is supposed to be.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds to me like you need a new display. It should work fine, upright or closed. Sounds to me like the cable is the issue. I would try to get that display exchanged from where you got it.
这个答案有帮助吗?
得分 3
5条评论:
Thanks for the quick answer. The display is a replacement from ifixit.
Not sure what you mean by upright or closed, but have considered a new display. However, not sure that is the issue, especially with the loose screw rattling around, for which I have found no place missing a screw ( I have not completely disassembled the phone, just opened it leaving the display cables attached.)
There is a spring contact in the upper left corner that makes a connection between the screen assy and the m-board (I assume). I don' t know it's specific function, but given its location precisely where the "pinching" together of the case has to happen, it appears possible that the pinch would secure that connection, and so I wonder if there a fault related to that contact that needs remedy.
完成的
The spring contact I am referring to is attached to the LCD shield plate. I also note now that the 2.7mm screw securing that corner of the shield is missing (the loose screw already mentioned is more like a 1.2mm). So, another anomaly in the upper left corner of the assembled phone.
完成的
Spring contact? You mean this?
[image|1022257]
完成的
that doesn't look like anything in my iPhone 5s.
完成的
Sorry. Got the phone wrong. Totally my fault. I'll snap a shot tomorrow, and see if we can get this sorted for you
完成的
添加一条评论
添加你的答案
Gary Tash 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 72
