跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
iPhone Front Facing Camera and Earpiece Not Working After Battery Inst
After replacing my battery the earpiece and front facing camera are not working. I've tried taking it apart and putting it back together. Any help would be much appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I ordered the proximity sensor. We'll see how it goes..
完成的
添加一条评论
3个答案
最有帮助的答案
Most likely you damaged your proximity sensor when you pulled the cable off the phone.
It happens even me as a tech doing phone repairs for over 5 years professionally. I still break these from time to time. Its a Easy and Cheap repair. You can get the part here for $5 http://www.mobiledefenders.com/catalogse...
Best of luck,
Steve
这个答案有帮助吗?
得分 4
2条评论:
It worked! Thank you very much.
完成的
Glad to Hear Keith. :)
完成的
添加一条评论
disconnect the battery and check the proxy sensor make sure the fpc connection is right. The camera and and loud speaker are on one flex cable, that's probably your issue.
这个答案有帮助吗?
得分 0
添加一条评论
Replace the camera cable and see if it is OK. If a replacement cable doesn’t solve the problem, then the only other potential issues are the camera itself, or damage to the logic board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
keith.a.wray 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 2,388
