跳转到主内容
这是一台发布于2012年的笔记本电脑,在日常使用环境中非常耐用。电脑配有13寸的屏幕,500G的硬盘,4GB的内存,Windows8.1系统可以在上面流畅的运行。
24 个问题 查看全部
How to do system image of disk that's going bad to new disk?
The hard drive in my Samsung is starting to make weird noises. I want to do a system image (or somethign similar) of this disk, buy a new disk drive (any suggestions for a good disk drive are welcome), and then install the new disk and copy everything over to the new disk. . I am hoping this process will help me not having to install windows and other softwares all over again. I would appreciate any and all guidance. Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
It would be better to load the OS fresh on the new drive than to copy from one that may be failing. At this point, you should not turn on the hard drive until the new one has been set up with fresh OS and copy only data. The performance will be better this way once you get everything installed.
完成的
The best time to create an image is shortly after setting up a fresh image with the apps installed and the updates current. You can find different imaging apps to help create an ISO that you can use to restore after problems like failing hard drive. Making an image of an OS that has a failing drive will faithfully reproduce the bad disk reads.
完成的
添加一条评论
1个答案
已选择的解决方案
1) first leave the original hard drive in the computer
2) connect your new one via USB
3) install Macrium Reflect free to the old hard drive
http://www.macrium.com/reflectfree.aspx
4) run Macrium Reflect, and clone to the new one
5) swap out the old for the new
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Eric 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 79
