跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Proximity sensor doesn't work properly after screen replacement
After I changed the iPhone 6s LCD the proximity sensor work properly. If I put my thumb over it works, but When I use it in a phone conversation it goes and off all the time. It didn't do this with the broken screen even after I put my old broken glass on again. I understand it's something about the new LCD that's wrong. It's AAA quality.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
might just not be seated correctly. Give it a clean and check its still fully attached to the ribbon cable
完成的
Thanks Eric, it's just so weird. It happens every time I change 6s and never when I change 6.
完成的
Depending on the color of the screen you may have to transfer over a filter that is only relevant on white screens. You will find a white diffuser square in the little window where the proximity lens sits.
完成的
@techrx that white diffuser square is actually for the ambient light sensor, not the proximity sensor.
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
More than likely the quality of screen you're using, or possibly the way you're positioning it.
Make sure to glue the proximity bracket in the correct position.
Always make sure to use a little heat when removing the camera proximity, as this then lessens the chance of damaging it.
这个答案有帮助吗?
得分 1
添加一条评论
It is often just an alignment issue when the proximity sensor doesnt work after a screen replacement. You will need to open it up and look closely for the plastic brackets that guide the sensor and camera into place. Sometimes the tiny clear plastic part comes from from the old screen sticking to the sensor. Then if the new screen already has a bracket you would not be able to line it up right.
If you checked and the old bracket didn't stick and move over just press down on the back of the sensor when it is perfectly lined up and feel for the click when you finally get to fall into place. Often this will fix the problem but you should keep some extra proximity sensors and front facing cameras in stock for when this happens.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aksel Fischer Aasheim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,007
