Proximity sensor doesn't work properly after screen replacement
After I changed the iPhone 6s LCD the proximity sensor work properly. If I put my thumb over it works, but When I use it in a phone conversation it goes and off all the time. It didn't do this with the broken screen even after I put my old broken glass on again. I understand it's something about the new LCD that's wrong. It's AAA quality.
4条评论
might just not be seated correctly. Give it a clean and check its still fully attached to the ribbon cable
由 Eric 完成的
Thanks Eric, it's just so weird. It happens every time I change 6s and never when I change 6.
由 Aksel Fischer Aasheim 完成的
Depending on the color of the screen you may have to transfer over a filter that is only relevant on white screens. You will find a white diffuser square in the little window where the proximity lens sits.
由 TechRx 完成的
@techrx that white diffuser square is actually for the ambient light sensor, not the proximity sensor.
由 PhoneOpsPlus 完成的
