跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Ipad2 Screen Not Working After Digitizer Panel Replacement
replaced ipad2 digitizer/glass now screen won't work, worked fine before have checked all connectios
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Try a hard reset (hold top and bottom button), sometimes changing the digitiser on this model will cause issues like no touch or no backlight, which is sorted by doing this.
Plug in your old digitiser to check, new one could be faulty considering it is an old part.
Make sure the digitiser cable is not creased too much, and is bent how it should be.
Also check the flap where the digitiser plugs in, to make sure it is present and the cable is fully pushed in.
If it is none of the above, it will be a logic board issue, not really worth repairing on a device this old though, it is better to just replace the whole board if this is the case.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
welchjr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 176
