跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
I can create 5GHz Network, But cannot connect to them.
Hello,
I have a "Macbook Pro 2016" and a "Huawei Mate 9" phone.
My Macbook can create 5GHz networks without any issues, and my Mate 9 can connect to them just fine, but not vise versa!
So I cannot connect to Phone-created 5GHz Hotspot with the Macbook.
These are the only 5GHz devices I have, and where I am right now, I don't have any access to the customer support.
Installed "WiFi Explorer" on Macbook and "PingTools Pro" wifi analyzer on the Phone.
WiFi Explorer does not show any 5GHz signal at all.
Is there any way, I can diagnose the issue here?
any help is appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Your phone's specs: Huawei Mate 9
完成的
添加一条评论
1个答案
已选择的解决方案
So to be sure I understand things you can access your MacBook from the Huawei Mate 9 phone via WiFi just not the other way.
With your Mac you created your own peer to peer AP an was able to get the Huawei Mate 9 to connect to your Mac and internet connection it offered.
Within the Huawei Mate 9 you would need to do the same if you wanted to leverage it as a WiFi hotspot. The Mac's P-to-P AP is not needed here only the Huawei Mate 9's P-to- P AP and then you would need to enable the routing function within the phone to use the cellular connection.
Looking at the user manual here: Huawei Mate 9 User Guide jump to the bottom of page 60 it talks about setting up a mobile hotspot. Did you follow the instructions?
Make sure to setup a secured network using WPA2. Alter your phones name and use it with the password you created on the Phone's hotspot settings on your Mac to connect to the phones AP. That should do it.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for replying,
I created a 5GHz Hotspot on Huawei Mate 9 with the right steps, my Macbook cannot see it or connect to it.
When I choose 2.4 GHz on the Phone it's fine, I can connect to it, the issue is only with 5GHz Hotspot.
I tried 5GHz P-to-P on my Macbook just to check if it works the other way and it did (I can connect to Macbook's 5GHz Network with my Phone).
I tried changing SSID on the phone, restarting Network Settings, restarting both devices, tried using both "WPA2" and "No Password (just to test if I can connect to it)", whitelisted Macbook's Wireless MAC Address, also tried using all 5GHz channels my Macbook supports (36,40,44, etc ...)
but still cannot see or connect to my Phone's 5GHz Hotspot using the Macbook.
TLDR; I'm doing everything correct, tried all settings, but I cannot connect to the 5GHz Hotspot created by my Phone.
I was hoping maybe to get some advanced technical advice here, because if the devices are broken why does it work the other way around?
完成的
You do have a very odd problem here! If you can setup a 2.4 GHz connection from the MacBook Pro to the Huawei Mate 9 phone then you've proven you are doing things correctly!
What that tells me is you likely found a bug in the Huawei Mate 9 phone! You'll need to speak directly to Huawei to make sure your phones firmware is up to date. If you can find a friend with the same model you should try to set it up with it. Or, try a second system to connect to your phone.
完成的
添加一条评论
添加你的答案
Dr. Horribles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,736
