跳转到主内容
A line of external hard drives by Western Digital, styled after hardbound books. Available in various editions from Essential, to Premium to World Edition.
My harddrive fell off a table and is now buzzing...
My harddrive fell and is now making a buzzing sound.......when I plug it into the computer nothing pops up anymore. Is it broken? Or has the disk just maybe gotten off track? Where can I take it to hopefully get it repaired?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Thank you. My entire business aka my LIFE is on that harddrive so yes I'll take your advice and send it to professionals. ...will they write the salvageable data onto a USB for me or something?
完成的
I'm pretty sure that's what they would do, whether they would have you bring your own or charge you for one I guess depends on the place. I would recommend looking to see if you have any local repair shops that could diagnose/fix it for you before you'd ship it somewhere. I know this probably wasn't the news you wanted to hear but hard drives are fragile tools. :/
完成的
Your Drive got physical Problem Read/Write Heads failure dont connect power again it might scratch platters visit any Professional Data Recovery firm if your data is important they might Recover Data in Basic cost ....
http://lifeguarddatarecovery.com/data-re...
完成的
Your Drive has physically damage. Read/Write Heads failure dont connect power again it might scratch platters. You can visit any Professional Data Recovery firm if your data is important they might Recover Data in Basic cost might Recover Data in affordable cost
https://lifeguarddatarecovery.com/ or in India https://lifeguarddatarecovery.in
完成的
添加一条评论
2个答案
已选择的解决方案
Any drop or knock can cause a head crash in your external hard drive, which means the read/write head of the external hard drive came in contact with the platters. If a hard drive is dropped and it isn’t working anymore, it is likely that the platters, arm or render head of the hard drive were damaged or misaligned from the impact. If the render head is trying to locate the data that it is searching for on the platters and it cannot find it, the arm will move back and forth across the platters several times. The head is attached to an arm that hits a stop every time it goes back and forth, which makes the clicking noise. You might be able to try a few software programs but they won't help much besides logical issues. Software really only addresses issues with reformatting, but even then, resorting to software may make matters worse. Your best bet is that if you truly have stuff of value on there is to send it to professionals. Otherwise, I have heard of a few companies that would send you a replacement but that obviously won't save your data.
这个答案有帮助吗?
得分 1
添加一条评论
Your drives requires platter cleaning and fixing through physical data recovery. Your Drive got physical Problem Read/Write Heads failure dont connect power again it might scratch platters visit any Professional Data Recovery firm if your data is important they might Recover Data in Basic cost ....
++http://lifeguarddatarecovery.in++
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keke T 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 69
总计 11,603
