跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Two white dots on screen
Why does my iPhone 6 have two white dots in top left hand corner
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
5条评论
How to fix iPhone 6 white dots???
完成的
Had the identical problem! A cold restart appears to have solved it!
完成的
The restart works! Simple and no more dots.
完成的
Worked instantly, thank you. Mani
完成的
@Jebin Joseph I can’t do mine
完成的
添加一条评论
11个答案
已选择的解决方案
Probably dead pixels. If it really bothers you, you could replace the display assembly
更换iPhone 6屏幕
iPhone 6 Screen
Replace a screen compatible with iPhone 6.  Includes all of the small parts pre-installed in the assembly, saving time and increasing the quality of your repair. 4.7 inch 750 x 1334 pixel IPS LCD Display.图片
产品
iPhone 6 Screen
$44.99
这个答案有帮助吗?
得分 2
5条评论:
It's actually not they are like perfectly defined not damaged liek it's like it's part of the home screen
完成的
Are you the same person as the original poster?
If you could provide a picture we could better help you fix the problem.
完成的
Does it look like this: https://postimg.cc/image/5xhiimsrx/ I've just had it come up on mine (under the EE sign top left)
完成的
Panic over - I turned phone off then back on again - hey presto, it's gone :)
完成的
I have the same problem
完成的
添加一条评论
最有帮助的答案
No, it's a software glitch. They appeared on my iPhone after I was wiping clean my screen. I just powered off the phone and restarted it and they went away.
这个答案有帮助吗?
得分 9
8条评论:
Thank you so much ,That did work
完成的
Awesome I had those did what you said and viola gone!! Thanks saved me heaps of money
完成的
Perfect! Thank you so much!
完成的
Omg ! Thanks it worked, it was really bothering me like some thing I could not tell weather it was one word or the other thanks to you it's all fixed !
完成的
Phew.. also was cleaning screen when it first appeared. Magic..it's gone
完成的
显示更多的3条评论
添加一条评论
White spots are usually from water damage or where there is something under the screen pushing pressure onto the LCD like a swollen battery. Replacing the screen will sort it if it's water damage.
这个答案有帮助吗?
得分 1
1条评论:
Hey Chris! You were right. My new screen I bought recently for an iphone XR has this problem. The screen is fine when the phone is not closed, but when it is closed(the screen and the housing), these white dots would show up, because of something pressing on the shield inside. I'm not sure what's causing these pressure, I definitely followed the ifixit guide to replace the digitizer and LCD and I don't know what's pressing on the screen. It's in lower right bottom near the corner. Can you please help me with this? Thanks!
完成的
添加一条评论
Hello everyone. I actually got my phone fixed not too long ago and dropped it in water. I have 2 white dots appearing in the middle of my phone. I know it could've came from the water or the way my screen was fixed. If I get my screen fix again will this go away?
这个答案有帮助吗?
得分 0
2条评论:
Try reseting your phone I should fix this problem but if not I would take it to apple to make sure it is not a bad LCD if it goes black IMMEDIATELY GO TO APPLE
完成的
I now had two white dots on my screen (iPhone 7) as well, after I installed the new iOS 12.1 program. I re-set my phone but the two dots did not go away. Then I just switched off the phone and on again, and it did work: the two dots have disappeared.
完成的
添加一条评论
It is dead pixels on the screen, you can see this article to solve your issues. Tips on How to Fix Dead Pixels on Your Screen May this can help you solve your issue, if it is useful, please click Yes to help others people, thank you.
这个答案有帮助吗?
得分 0
添加一条评论
Just restart your phone that's what I done !
这个答案有帮助吗?
得分 0
添加一条评论
I turned phone off and back on again - problem solved.
Thanks everyone :)
这个答案有帮助吗?
得分 0
添加一条评论
I turned phone on and off and they disappeared from screen!
这个答案有帮助吗?
得分 0
添加一条评论
Turn off the phone then on again the white dots will disappear
这个答案有帮助吗?
得分 0
添加一条评论
To everyone who insists that they are dead pixels, take a good look:
There is no way those are dead pixels. :D
这个答案有帮助吗?
得分 0
添加一条评论
I think it's someone snooping on me…I’ve got apps from sling? That I can't get get rid off and apps that say they draw over other apps? But I'm Android…My two dots are almost irridecent (spell check ) one lower right…One alttle lower right from center
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
zoki243701 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 33
总计 190,357
