跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Why won't microphone support screw bite?
On my wife's iPhone6, I was inspecting the bottom microphone. Basically the bottom mic stopped working to pick up speech. it would pick up blowing directly on it but not speech. Anyway I decided to remove the pentalobe screws, open the phone and then remove the microphone support so I could inspect the microphone hole. The phone was repaired once by a local shop before. The microphone support screw came out normally but when I went to replace it, the screw would not bite into the bottom board. I assume all these little Phillips 00 are the same diameter just different lengths. I'm guessing the last go round they might have stripped the socket threads? Any suggestions on getting the screw to set again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Inspect both the screw and the threaded hole . try running the screw into the hole without the microphone in place just to see if it will still thread in . If all is good then reseat the mic and make sure its down as far as it can go then run the screw in if necessary apply a little downward pressure . Make sure you don't cross threat the screw by making sure you have it perfectly straight . If it doesnt thread down without the mic then find another screw from another area of the phone that's the same length and try it. Just to clarify you were using the same screw you took out right? There are a few screws on the iphone that are different lengths and do need to be returned to the same spots on the phone . if you get them wrong they can cause serious problems with bottoming out and shorting the phone. Hope this helps
这个答案有帮助吗?
得分 3
1条评论:
At the time I did try threading a screw in the socket without the microphone support in place to rule out using too short of a screw. The only 3 screws I removed when I did this were the 2 penatalobes and the mic support so I was trying the Phillips head. I haven't tried a screw from another part of the phone yet. For the mic support the threaded hole looks like it is a graphite donut inside a metal ring. I was guessing that bit softer and was stripped during a prior repair. I remember it looking like it had some loctite on the screw so maybe the shop stripped it... would explain why it "loosened" but wouldn't tighten again.
完成的
添加一条评论
最有帮助的答案
There are three Phillips screws that look similar for headphone jack and bottom microphone.
The bottom microphone is the longer one.
Headphone jack uses two shorter ones.
Check those 3 screws.
Probably the longer one screwed into headphone jack screws.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
ChrisK 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 145
