跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
camera and flash not working after strip down
i did a strip down to change my charge port and once installed the rear camera and flash started to play up. also systemUI report came up.
what i have discovered is when i take the phone out of its metal back case and start it up, every thing works well!! once i put it all back together it stops working again after a few days!! i feel its more of a software issue the hardware?
i have factory reset it many time but the rear cam and flash only works when i dismantle it!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
10条评论
i forgot to mention that the only thing i removed and fitted was the board that hold the phono jack, cleaned it and put it back! could this cause the software to play up ? i did check the cables where the flash and camera is attached but all seemed ok...
完成的
Hi,
Just reading your original question. 'It works well out of its' metal back case' to me implies that when it is in its' METAL case either the metal is touching something it shouldn't or the case is applying pressure to something it shouldn't. Metal is a conductor. Check that the case will not come into contact with anything that it shouldn't. Just a thought
完成的
Or if extremely unlucky the connection for the rear camera is loose and needs to be replugging in. If that is the case that would be the assembler at fault in the factory.
完成的
thats guys i checked that teminals are all good so it seems... but i was thinking possibly not earthing propperly on to the case or like jayeff said possible pressure applying some how.... not sure but maybe i could have damaged something or could static cause it to play up??
will try 4th tear down !
完成的
so update... i took it apart and the camera and flash started to work again also when i fitted back in the case but only lasted about 4 day not its not working. im pretty sure it will once i take it out again and re fit. any ideas??
完成的
显示更多的5条评论
添加一条评论
1个答案
最有帮助的答案
Check for damaged connectors and cables. If they are not damaged, try cleaning the connectors for the flash and camera using 91% Isopropyl Rubbing Alcohol. It is non-corrosive and non-conductive, and will remove the oils left behind by contact with human skin, making it perfect to clean the contacts with.
EDIT FOR WARNING: Unplug battery BEFORE using isopropyl alcohol on the phone inside.
这个答案有帮助吗?
得分 1
1条评论:
Keep in mind though that it is flammable. If something sparks, it will go up. Good news it dries very quickly, so by time you get the phone back together, that would no longer be an issue.
完成的
添加一条评论
添加你的答案
fikret 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,724
