跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Ghost clicks after 3 minutes of usage
On my iPhone 5s, to works perfect for first 3/4 minutes of usage.
Then it seddeny starts doing ghost clicks and non responsive.
(I also see some vertical lines on display)
Then I lock the device (turn off display), wait for 2 min Aprox. Unlock again and it works perfectly for next 2/3 minutes.
As the cycle goes on.
Is this a genuine bug or specially granted to me?
How can I fx it?
Already tried
Reset
Restore
Reboots
Re-fixing display and touch strips.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
It more than likely sounds you received a faulty screen, or you may have damaged it installing it.
Try another screen and see if that resolves your issue, as there is a lot of garbage being sold on the likes of eBay etc. :-)
这个答案有帮助吗?
得分 1
添加一条评论
I recently had a similar issue on my iPhone 5. The glass had separated some from the LCD and dust had gotten in there. It would open apps, type gibberish in text messages, etc. Replacing the display assembly fixed it.
iPhone 5s 显示屏更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mehran 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 5
总计 101
