跳转到主内容
针对近期推出的Mac笔记本电脑以及台式机的完全拆卸和组装指南。
42815 个问题 查看全部
Missing a start up drive
I have a 2012 (late) 2.6 i7 with server and I have lost my start up drive
Update (08/04/2017)
I don't not have an external hard drive, but some of the information I understood and tried and it help but now there's something else that has evolved from this.
What I have is a 2012 mid year with 1/2 being the computer the other a server.
I'm a 65 year old dork, not understanding the server side but when I lost my startup everything loaded over onto the server.
I live in the mountains above Santa Cruz on one side and San Jose on the other... I spend a lot of time in AZ because I'm a cancer caregiver for my daughter in law, so when I get home I like to tinker on things if that makes sense...
The problem that is also a concern here is that the blower is on all the time.
Sorry about the history but wanted to let you know I've tried your suggestions
MB
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you tell us the exact model of your system. Apple has produced quite a few systems so we really need to know what you have to help you. To help take a look at this link: EveryMac it is the definitive listing of every system Apple has made! Paste your systems URL here for us to see.
完成的
Can you give us a better clue ;-} Mid 2012 doesn't tell us much ;-{
Do you have a laptop or do you have a desktop system?
Can you pick your system out of this list: Mac's released in 2012 << Click on the blue link here. Once you know paste the URL of the system here for us to see.
Once we know we can guide you better. If you still can't figure out what you have. Maybe one of your son's kids can help you here.
完成的
添加一条评论
1个答案
最有帮助的答案
Could you be a bit more specific? Do you know what was happening leading up to the current problem?
I am going to write all of the following assuming you have a mechanical Hard disk, NOT and SSD. If you have an SSD some of the following information will not apply (such as an audible verification of the device working)
I am going to assume that when you attempt to power on you're still hearing the chime, which means the Logic Board and RAM are checking out okay. If you get a grey screen that means the video card is also fine (a sub segment of the Logic Board) and if you get to a flashing folder icon with a question mark then you have one of a few different possibilities.
First and easiest check would be to hold down the option key as you are trying to power the system on. If you see a blank grey screen with an icon showing what looks like a Hard Disk and the words Recovery HD XX.XX where the XX is what version of the macOS you have/had installed then you may have something going on with your main partition on your drive.
If you see nothing on the screen when pressing option try putting your ear on the computer on the right palm rest area, listen for a spinning whirring sound. it should be pretty pronounced and this will tell you if your disk is getting power, or if it is even spinning (it could have power and not be spinning, or it could not have power at all, or it could be working fine as far as the system is concerned)
If you don't hear sound you'll need one of three things. Directory repair, a new drive, or a new drive cable. The cables have been known to fail over time, due to shock or flexion (breaks in the copper) and they're easy enough to replace in both cases. If you have access to a 'known-good-laptop' hard drive to install and test with try that first, if you have the same symptoms, then its likely the cable. If you try it and it does work then its likely the drive needs directory repair or whole replacement.
Finally if you have access to a bootable copy of the OS or the OS installer you could try using Disk Utility on the recovery partition/bootable copy to repair the internal disk if its present to the system (if it can see it)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Crackerbox 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 73
