跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
Why won't my iPad 2 recharge
I have had the iPad2 plugged in and charging for the past 6 hours and the battery symbol is still showing 0% battery charge.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi Sharon, here are a few things you should check:
  • Are you using a genuine Apple 30-pin cable and charging block? If not, then you may have a poor quality cable or brick.
  • Your battery may be dead. The iPad 2 is fairly old and if it was used regularly, the battery may just be finished. The logical thing to try is to replace the battery but doing so on iPads is a bit more difficult than on a phone.
  • If a new battery doesn't solve your problem, then you may have a defective charging circuit on the logic board. This can be caused by non-genuine charging blocks or falls/impacts on the tablet.
You can check out the iFixit guide on replacing the battery. There are a lot of potential traps when removing the digitizer, handling the LCD and replacing the battery but it is certainly doable if you are used to fixing stuff.
You should download CoconutBattery (for Mac) or 3uTools for Windows. They have the ability to test your battery. If you have less than 80% of the original design capacity, you should consider changing the battery. If you have less than 60%, then you HAVE to change the battery.
这个答案有帮助吗?
得分 1
添加一条评论
On my ipad2 it started not charging most likely for
A bump it received that damaged the volume control. However I have found that letting the iPad battery completely drain does something. I plug it in and the next day it is 100%.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sharon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 188
