跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
208 个问题 查看全部
Where does this spring belong
I found a spring after removing the fan for my late 2012 Mac mini. The only springs I could find online pertains only to the ones for the heat sink. I did not nor have I ever removed/replaced the heat sink of my MM. So where did the spring come from?
Another question is why doesn't the screw for the fan/cowling come off? It comes off the motherboard fine but it's stuck holding the cowling and fan together? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
One the first picture of the fan, showing the black screw. The spring goes in under the screw (i.e. The screw goes threw the middle of the spring) to create tension and push the fan down. Hope that helps!!
这个答案有帮助吗?
得分 3
1条评论:
Thank you. Does it go in between the heat sink and cowling or in between the heat sink and the logic board?
完成的
添加一条评论
添加你的答案
Rodney B Ungwiluk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 407
