跳转到主内容
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
93 个问题 查看全部
Upgrade Fusion>SSD--when to break fusion link?
Hello!
I'm planning to crack open my mac and replace the HDD part of my current Fusion setup (but leave the blade SSD in place). I think I understand what I need to do from physical standpoint, and I understand how to break the Fusion drive in Terminal. Thanks for all the great advice on that in these forums.
What I'm not so sure about is when I need to actually break the Fusion link in Terminal. Would I do that before or after I make the physical switch of the drives?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You will need to do it before you make the physical switch. Just make sure you backed up any data on the "fusion drive", before you break the link through terminal because that destroys the partitions and you will lose the data on those drives.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
John Doestein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 89
