跳转到主内容
Ice buildup behind freezer wall
Our 12 year old Whirlpool fridge developed this problem Friday, and a partial diagnosis is our defrost heater is bad (no continuity) causing ice to build up on the coils behind the freezer's back wall and block airflow. I can obtain this part myself for around 100 bucks at a brick and mortar, or wait a couple days for online delivery for 60 bucks, but if this is not the ONLY cause of this problem, I would rather just get a new fridge.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The defrost timer and the defrost thermostat may also be involved with that circuit. Without knowing the exact model of your fridge, we are limited as to what advice we can give. That being said, nobody can guarantee 100% that your only issue is the defrost heater. All you can do is replace the known defective part/parts, and see if it performs to specifications.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joel Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 2,921
