跳转到主内容
OnePlus' second entry into the Android phone market, the OnePlus 2, was released on August 11th 2015.
20 个问题 查看全部
Broke the antenna connection when replacing screen
Hi,
I removed the antenna wire a little too hard when I was going about replacing the screen and now it won't connect to the bottom board, I assume I just need to solder it onto the bottom and everything will work fine.
But I thought I'd ask just incase, has anyone else had this issue and fixed it by soldering?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi was it just the wire that was broken? If so you can buy replacement antenna cables pretty cheap, if it was the actual connection on the motherboard you my need to send it in for repair unless you have experience with this type of repair
这个答案有帮助吗?
得分 0
1条评论:
Hi,
Thanks for replying!
The wire isn't actually broken, I think the connection to the bottom board isn't solid.
I get a connection but it drops randomly and it's slower than dail up sometimes, I think because the wire isn't connected to the board properly its not working correctly.
I hope I don't have to take it to a shop, I may try soldering it, do you think it's a good idea?
Thanks again
完成的
添加一条评论
添加你的答案
Rohit Mohan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 110
