跳转到主内容
The HP Deskjet F4480 Printer/Copier/Scanner. This printer was intended for home or small office use.
19 个问题 查看全部
Printer will not print typed text.
I have a MacBook computer and an hp deskjet f4480 printer. My issue is that when I print some sort of template, example would be my W-2 form, with text typed in, all that prints is the template, none of the typed text. Why is this? What can I do to fix it? Obviously the printer is not reading the typed in information.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Printers print the information that is sent to it, printers do not have much processing capabilities. The problem is more likely to be in the settings of the print job or the page layout. What applications are you using to print? Can you do a print preview to see if the typed text is being added to the print job?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nathansdlr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 541
