跳转到主内容
加入维修社区 - 创建账户
在与惠普合并前,康柏电脑制造全系列的笔记本电脑。 现在他们由惠普制造,拥有最基础功能的电脑。
capslock flashing and black screen
black screen then caps lock keeps on flashing/blinking. one time i try to drain the battery then it works..but when this problem arises again it doesnt work again..i tried to remove the battery also..but still it doesnt work anymore..what should i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I have. Problem in my computer compaq presario 061 its blink black pops on monitor when i used whats problem
完成的
My laptop compaq presario cq40 black screen with blinking under space bar help me
完成的
添加一条评论
1个答案
已选择的解决方案
This could be an host of issues any one of which can cause this so lets start with the basic. remove the laptop battery and disconnect the power then hold down the power button for 60 seconds. then reinstall the battery and plug in the power and boot the laptop. if it works it was a case of static discharge if there is no joy lets move on to the ram . Remove one stick of ram and try to boot the laptop if it doesnt boot then move that stick to a different dimm slot. and try to boot again if the laptop boots it means one stick of ram was bad if not then switch out and test with the other stick keep trying until you have tried each dimm in each slot . If you have no joy then we move on to the APU. try pluging in an external monitor. If it works then your LCD screen is bad and will need to be replaced if it doesn't work then the issue is probably with the APU. Hope this helps
这个答案有帮助吗?
得分 6
2条评论:
yes reinserting the battery while holding down the power button gives joy, but it's temporary joy. Actually it's annoying to do it repeatedly. What is the solution to make it normal?
完成的
replace the battery.
完成的
添加一条评论
添加你的答案
rena ballesteros 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 17,052
