跳转到主内容
The Samsung Galaxy J2 is an Android smartphone that was released in November of 2016.
100 个问题 查看全部
Hi. I dropped my Samsung Galaxy J2 and the screen turned black
Hi. I dropped my Samsung Galaxy J2 on its back and the screen turned black. I can hear the sound when i restart my phone, but the screen is always black. What should i do ? I remove the battery then put it back again but still don't work. Please help i'm desperate !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
10条评论
i also have the same problem even worse my phone got hot
完成的
Plasae help me j200h phone dropid after display problem
完成的
My samsung j2 mobile screen sometimes black . How i can stop this problem?
完成的
Replace the LCD....it's 1000 solution for u
完成的
My samsong galagsy j2 have black vapour on the top screen, the vapour gradually flotting down the screen and within 24 hours the phone screen was totally black. What could be the problem? Is it that the phone screen as expired or it is virors problem? Please I need help.
完成的
显示更多的5条评论
添加一条评论
4个答案
已选择的解决方案
Hi,
I believe that there could be 2 main reasons why your phone's screen is black:
1.After the drop your LCD connector disconnected.
2.Your LCD broke from the impact.
In any of these cases you would have to remove the screen and check the connector, if that's not the case you will need to replace the display.
这个答案有帮助吗?
得分 7
3条评论:
how do you remove the screen
完成的
Yeah..Exactly...How do I remove the screen to cheak if the LCD connector is disconnected or my LCD broke ???
完成的
I did many things like removing the battery, charging the phone over and over to see if the phone is working or not but it still do the same so what sign will it tell to tell if the LCD is broken and how can I also find out that the LCD connector is disconnected? and also what is LCD?
完成的
添加一条评论
When you remove the battery cover look on the back of the phone. There should be a small compartment on the left side just below the camera. Pop the cover off and it will reveal the connector for the LCD screen. Check to make sure the connector is plugged in. To check to see if your screen is the problem, use a friends phone and plug their screen directly into your phone. If their screen lights up and works off of your phone's motherboard then you have a bad screen.
这个答案有帮助吗?
得分 1
添加一条评论
Hi
So heres what I think have might happen ed
1.the back light died.
2.the connection to the lcd might have come loss
I hope this helps out
这个答案有帮助吗?
得分 1
添加一条评论
then you remove ur phone battery and hold power key and volume up bottom and then fix ur battery then rest ur phone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Genevieve 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 50
总计 11,438
