跳转到主内容
Repair guides and support for the 2nd-generation Renault Mégane, also known as the Renault Mégane II.
Why is there oil in my renault intake/inlet manifold
Hi Guyz my name is Steven I own a Renault Megane 2005 2.0L 16v Coupe Cabriolet these are the problems I have.
<1st> the car revs itself from 2000 to 3500 RPM at IDLE and even when I driving it Revs its self
<2nd> the car has the "Check Injection" message on Dashboard, when the engine is it has a rough Idling sounds like its firing on 3 pistons. when I sent it to the diagnostics yesterday it said nothing about the injector rail, coil or plugs which I suspected then I assumed that it was an air leak some under the manifold cause I also noticed that the throttle body doesn't close completely. so I removed the intake manifold and I found that it had oil in it which was strange cause from my knowledge only air moves there.
Now I don't know what to do, please advise
Regards
Nas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hey m8 did u resolve this issue with ur megane as I'm currently goin thru what sounds like the very same problem with having spent alot of time trying to solve it in now to the point where the only thing that's gonna fix it is a nice big match box
完成的
添加一条评论
1个答案
it may be caused by map sensor (top left on engine), check piping for evap sensor too
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bulelani Ntabeni 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 39
总计 2,965
