跳转到主内容
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
100 个问题 查看全部
Not turning on. New battery. Only turn on with charger plugged in and
I changed the battery since it was not charging at all, I got my first replacement it came a little bended right in the middle, where the connection is made, it worked fine for 2 days then it was not working at all, I just got my new battery and it turns out that when I plug it in it shows 75% the screen shuts off, then I press the HOME button and it shows the battery with electric ray like if I just plug it in.
Also it says for example 75% if I unplug it it will not turn on and I want to do a hard reset, it will only work if it's plugged in and with a minor move it will cut off the process.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
GOT IT!! It was the battery connector clip on the tablet, which holds the connector coming from the battery. It was loose, so it was not making the connection.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Liz Tang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 55
