跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Dead, no power. All voltage rails test good
So looking for a motherboard specialist who can possibly shed some new light/ideas for me. I'm working on this iPhone 6 that is completely dead. Doesn't recognize plugged in or unplugged w/ good known screen and battery/charging port.
Weird thing is I've literally tested just about every voltage rail from vcc_main to pp_cpu and pp_gpu to 3v0_tristar and literally about 15 other main ones. All test short free and correct voltage.
Phone is not liquid damaged.
Any possible guesses or other ideas to try? I've already replaced pmic twice as well for giggles w/ no improvement.
My next step is to look into bl driver as from my experience this can cause goofiness but once again, incoming and outgoing from that bga test perfect.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
sir
will u please help me to trace dead iPhone
完成的
添加一条评论
3个答案
已选择的解决方案
Hi Stephen. When you say you tested the rails, did you measure their resistance to ground or did you measure the actual voltages? You talk about the backlight...does iTunes recognize the board with only a battery and charge port connected?
There is a very real possibility that you have a defective major IC or broken traces within the board.
这个答案有帮助吗?
得分 1
1条评论:
Unfortunately iTunes doesn't recognize board. I've had iTunes sometimes not even recognize the phone when its just a backlight problem...weirdly. I tested both continuity to ground as well as actual voltages. I believe your right and suspected trace damage.
完成的
添加一条评论
can u please help me to identify the voltage rails of iPhones
这个答案有帮助吗?
得分 0
添加一条评论
Bl ic chenge butt ishu not sol
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephen Elliott 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 673
