跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Can I use a home button from another iPhone 6s to retain touch id?
I have a broken home button but I would like to keep touch id so I don't want a replacement home button. If I get a original home button off another iphone 6s will i be able to keep touch id?
Thank you for you're help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
you can your but touch id function wont work why because your original touch id paired with cpu...
if you put another touch id finger print not work
so you not able to use touch id function
you can use for menu button function
这个答案有帮助吗?
得分 2
1条评论:
That's what I was wondering. Because I have two original home buttons from apple but one broke so I thought I could change them over. I guess they're locked to the logic tho .
Thanks for everyone's help
完成的
添加一条评论
Doesn't matter if it is original or not, if you replace the home button Touch ID will never work again UNLESS you take it to Apple and say it doesn't work. They will use their magic pairing thingermabobber and it will work again. So yes, it CAN work again, but not without a trip to Apple! :)
Here's the part:
[关联产品丢失或禁用: IF314-013]
这个答案有帮助吗?
得分 1
添加一条评论
Hi
Plz Go Thorugh Below Link
https://www.youtube.com/watch?v=Zv1LO9vG...
Hope it Works
Thanks
Varun
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shawn Daw 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 16
总计 1,466
