跳转到主内容
第一代苹果iPad 配备有WiFi 提供16.32或64GB 型号为A1219 维修是直接的不需要任何加热。
130 个问题 查看全部
DC power connection to iPad Gen 1 - A1337
Hi All, I hope someone here can help, I need the ability to power up the 1st Gen iPad without the battery by using a DC PSU, I've done this with other iDevices but unable to find pinouts online for the Gen1 iPad. does anyone here know the answer to this it would be very much appreciated.
Update (02/02/2017)
Hi Zakk,
Thanks for your response, I'm actually wanting to power on the iPad 1 without a battery, for example they make a special cable to power iPads but not the iPad Gen 1 https://www.aliexpress.com/item/Professi...
I've seen people solder wired to the power terminals of an iPhone or iPad logic board and connect a DC PSU to power it on, I know it seems extreme but its only for data recovery purposes. I was hoping to find the rails on the iPad 1 logic board that I could connect a DC power source to?
Cheers
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hey mate. The first gen iPad uses the old 30pin connector. This photo should help you with the pin out. Any other questions, feel free to ask. http://4.bp.blogspot.com/-Rlo4uRzUh7o/Tf...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nicholas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 354
